LOAD BALANCING and security SOLUTIONS
A Unified, Easy-to-Use Platform for Load Balancing and Protection
SKUDONET brings L4/L7 traffic distribution, high availability, and integrated web security together in a single, easy-to-use Web GUI—without extra modules, hidden costs, or complex deployments.
Mawa Solutions
Fujitsu
Cardzone
TATA Communications
SKUDONET Editions
SKUDONET offers two editions tailored to different needs: the Community Edition for testing and entry-level projects, and the Enterprise Edition for mission-critical environments.
COMMUNITY EDITION
Open Source Load Balancer
The open-source, free version of SKUDONET. Ideal for testing projects, learning environments, or small businesses that need an entry-level load balancing solution with fundamental security features included — at no cost.
Learn More
SKUDONET Community edition login
ENTERPRISE EDITION
Application Delivery Controller
The enterprise-grade SKUDONET solution. It provides professional support, advanced load balancing, and comprehensive security capabilities for mission-critical environments — all managed through an intuitive Web GUI.
Learn More
SKUDONET Enterrpise Edition new GUI 2
Key Metrics & Insights
475,000+ RPS
L4 throughput with only 27.7% CPU usage
17M+ users/second
Theoretical capacity under L4xNAT
100,000+ RPS (HTTP)
Stable L7 processing even at maximum load
93,000+ RPS (HTTPS)
High-performance SSL/TLS offloading
Application Delivery & Deployment Flexibility
Ensure continuous availability and adapt to any IT infrastructure with SKUDONET’s global traffic management and flexible deployment options.
SkudoCloud
Cloud Load Balancer
The SaaS version of SKUDONET, designed for organizations that need a cloud-based load balancer without investing in their own infrastructure. SkudoCloud is fully scalable, easy to manage, and completely maintained by our team.
Discover SkudoCloud
Security Features
Web Application Firewall (WAF)
Defense against OWASP Top 10 and other web attacks.
TLS/SSL Inspection
Secure encrypted traffic inspection with minimal impact on performance.
DDoS Protection
Mitigation of distributed denial-of-service attacks.
API Protection
Safeguard critical interfaces with dedicated security.
Support and Services Support & Services
SKUDONET provides different levels of support depending on the edition and needs of each customer
SKUDONET Support & Services
Community Forum.
Access the SKUDONET Forum to share knowledge and get help from other users.
Learn more
Enterprise Service Plans.
Annual contracts that include updates, technical support or security guidance.
Learn more
Knowledge Base.
A continuously updated resource with guides, best practices, and technical documentation.
Learn more
Consulting Services.
Tailored assistance for organizations that require custom deployments or specific integrations.
Learn more
contact us
Need Help Choosing the Version that Best Matches Your Needs?
If you need help choosing the custom Enterprise load balancer that best suits you and your business, our technical support team will advise you on everything you need.
