Forum
Migrate from Comuni...
Notifications
Clear all
[Solved] Migrate from Comunity edition to SVA10000 Virtual Appliance
3 Users
0 Reactions
(@jnunez)
New Member
Topic starter   [#688]
Hi,
I download, install and configured skudonet community edition, and after, i bought the Subscription Plan.
Is it necessary to migrate from one version to the other one? I think both of them are almost the same, but there are little differences, right? Is there any guide for doing that migration?
Thanks!
Rendone
(@rendone)
SKUDONET Engineer Moderator
Good day,
You can not convert a Community Edition to Enterprise Edition. It is necessary to install the SVA10000 Virtual Appliance.
Then, you can try to do a backup in Community Edition and import it into Enterprise Edition.
As a note, all the questions about Enterprise Edition should be managed via Enterprise support channels.
(@jnunez)
New Member
Topic starter
@rendone
Thanks for the information, I suppose it will be like that, but I prefer to ask
emiliocm
(@emiliocm)
Doubt solved.
Thanks for the confirmation.
Share:
