Forum
Memory and Graph Is...
Notifications
Clear all
[Solved] Memory and Graph Issues
2 Users
0 Reactions
(@rgonzaleza)
Active Member
Topic starter   [#17]
Hi Emilio, I just wanted to thank you for your help and guidance, it has been very helpful.
Also, we have two issues righ now, one with memory and one with farms graphics.
for the memory we have found that suddenly memory goes up, we have two nodes with 8GB ram each, is there any special configuration on how to handle this?
On the other side, we are not able to get the Farms graphs, despite having connections we see nothing on the graphs. I attached an image where you can see the issue.
Is there any documentation where we can see how many concurrent sessions can we have in this version?
Again, thanks for your help, I really hope you can guide me again.
Quote
emiliocm
(@emiliocm)
SKUDONET Engineer Moderator
Hi  @rgonzaleza
Regarding memory usage, there aren't scheduled tasks using memory, so right now, I cannot figure out where the root cause should be without looking at your system. Anyway, did you install any additional software? That could explain the usage.  Can you share the memory usage?
Regarding the attached docx, what I see is 1 farm and 1 service with 2 backends. I understand the service is configured in the same farm. In my first view it seems to be an issue, but it is strange as there is no modified code in the latest community edition related to stats, and this part is quite stable.
Anyway, could you generate supportsave for my review? as there is sensitive data in the supportsave please send it to our private email: community (at) skudonet (dot) com
Thanks!
ReplyQuote
emiliocm
(@emiliocm)
Issue analyzed in private, memory and CPU are running properly.
ReplyQuote
Share:
